same here, pending results on my cam, and best ratios for it. N/A and nitrous.
Im for sure buying a set of these too.
i def will be buyin a set of these when they come out94 BerrettaZ26 3400,5 spd, aluminum flywheel, stg3+ spec clutch, poly mounts everywhere, strut and strut to rad braces, s&s headers, euro mirrors, and taillights, E36 headlights, blk widow spoiler, GTU rimz, intrax, KYB, OBD2 swap rear disk swap with ss lines and ss clutch line, addco rear bar
I deffinately will get a set. I just was hoping to save a little money if possible. The stock cam with .484 lift would be quite nice for a turbo setup. I guess I need to start saving $20 a week. Haha!
Also, will these rockers require custom pushrods?
-Joseph
well i will try to keep prices down as much as possible, but i dont think that they higher ratios will cost much more than the lower ones...ie 1.8 price wouldnt be far off from the 1.6 price, but there will be some, they take more engineering and material to a point...
Nothing wrong with better springs, but I was just referring to the post above that talked about a cam being daunting possibly. I think sliding in a cam would be easier than messing with springs under tension, lol. Can you change springs without pulling the motor? Or is there not enough room?sigpic New 2010 project (click image)
you can change springs without pulling the heads.
use something like this
if you use the C clamp style then you have to pull the head.sigpic
99 Grand Am GT
