does anyone see why this bin wont start my car, it acts like it may be to high in time. It will hit then drag. Also did I disable my egr, vats, and speed limiter correctly, it should have 24lb injectors also. thanks
bin file won't run
comparing to my slightly modded 3.1, all of your VE tables are extremely high, at least 2x as much as mine. timing looks ok to me. your open loop AFR looks rich too. is the 88.xdf a stock file for 3400?Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
that bin is AFU.. those VE tables are all wacked out and the spark advance table isn't right either...
Try this one..Attached Files
well I just tryed it and its better it would start but would't idle. What would you adjust to adjust the timing at start. If it had a distributor I would advance it some if that says anything. I also believe it may be getting a little more gas when starting since it has a strong gas smell. Would putting the injectors to 25lb help any?
If you are willing to switch to $A1 code i could help you out a bunch more... either way, datalogs of it running would be nice.
I have the data cable but haven't figured it out yet but I don't think it will idle long enough to datalog. If your talking about the A1.xdf I will try it, it dosen't matter what it is to me as long as it runs. This is my first time trying to tune. I'm ging to disconnect the battery cable tonight to see if that will help.
is the BPC supposed to be that low? i'm at 224Andy
with 24lb injectors, yes 150 is about where it should be.
I'll look more into that bin today and see if i can find anything weird.
how long does one have to run to get a datalog? The car will fire up if you hold it on the bottom but will die after it revs up to about 3000 rpm's.
It acts like you sprayed starting fluid or gas in the throttle body and it had no gas in the tank, as if the injectors isn't firing. It has 3/4 tank of gas though.Last edited by 923.4v6; 08-10-2008, 08:48 PM.
