forget your cams, theyre worthless.......
2012 Chevy Sonic Turbo 6spd
1970 M35A2 Deuce and a Half, Spin on filters, Turned up IP, HIDs, Flat Black, 11.00x20 singles.Tags: None
Originally posted by sprucegagt View PostNothing new. I believe the idea has been around for at least 10 years.
Perhaps some of the new improvements over it will get more attention from auto manufacturers, but I don't really see this replacing current technology just yet.
I think there were big problems sealing the engine under actual operating conditions. Sealing the valves was a problem once the engine was hot and when faced with the pressures of cumbustion.
There is another spring less valvetrain configuration I just read in my Racecar Engineering magazine. basically it is a standard valve but the spring is eliminated and the tip of the valve is locked into a roller follower that follows a groove in an overhead cam that both pulls and pushes the valve. This way there is no need for the spring and the intake and closing events can be a completly different ramp. Works great in testing and looked fairly simple. Also there was no need for major cylinder head re design as long as you were working with an oHC engine.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Originally posted by betterthanyou View PostThere is another spring less valvetrain configuration I just read in my Racecar Engineering magazine. basically it is a standard valve but the spring is eliminated and the tip of the valve is locked into a roller follower that follows a groove in an overhead cam that both pulls and pushes the valve. This way there is no need for the spring and the intake and closing events can be a completly different ramp. Works great in testing and looked fairly simple.
yah and also dont forget about the electronically activated valves via solenoids...that seems to be the word for a few years. about how you could "push a button" and you could have a high performance engine. in theory it all sounds great...
Originally posted by gectek View Postyah and also dont forget about the electronically activated valves via solenoids...that seems to be the word for a few years. about how you could "push a button" and you could have a high performance engine. in theory it all sounds great...-60v6's 2nd Jon M.
I always wondered years ago why they hadn't gone with solenoids, but the answer I had recieved when talking with a few people in the industry (early 90's) was that there were no solenoids that could handle the duty cycle with any amount of durability. Since they are using them in some race engines now, I'm guessing that has been somewhat overcome. If solenoids could be reasonably used for street driven vehicles, the performance tuning would be virtually unlimited. Talk about tuning to a straight torque curve!
that wouldnt be like ducatis stuff. this guy used a creative rotating ball valve. not a poppet valve. thats the diff.
to what everyone esle is saying, ive found many reasearch papers and such rfrom large to small corps and even some written by engineering students explaining the who what where why and why not. its very very interesting.
bottom lines, solenoids are too slow, require too much energy, and would be harsh and complicated to control/ (you really have to read into to it to understand why i say these things)
electro-hydraulic poppet valves are in use now on an international semi. it works. again...diesel...slow moving. but has made some incredible improvements.
and to add to the EHV, they can be made to travel at speeds far beyond what any of our engines could do, but no one has the $$$ or time to invest into it. no one really likes the idea for some reason.
electromagnetic ball valve (my kinda idea) would be incredible. versitle infinite amount of tune ablility. no valve to piston clearance issues, incredible increase in cfm flow. less moving parts. i could go on and on.
draw backs...many. sealing, electromagnets going hay wire, learning to control it, programing, software, power, durability3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
yes they did. its been replaced with the new DOD engines.3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
Originally posted by merlot566jka View Postthat wouldnt be like ducatis stuff. this guy used a creative rotating ball valve. not a poppet valve. thats the diff.
I had thought of one a long time ago that still used springs, but it was a little different, while still using a cam. The valves would be small cylindrical shaped rods I guess you could call them. The would have a hole in them, and a spring would force them to one side, against the cam. When the cam lobe came in contact with the lifter, or a roller tip in the end of the "valve" it would push on it, moving the hole in it into alignment with the hole in the head which would lead to the intake in one direction, and cylinder in the other. To break it down into something really simple, take 3 2x4's, stack them up flat on top of each other (3 1/2 face to 3 1/2 inch face), drill a hole through them, and then fix the top and bottom one, and slide the middle one back and forth to open and close off the flow in the holes. Again, we come into the problem of sealing. But then there would be no valve head in the way to block flow and the full port could be used. But now knowing what I know about engines, the valves can help throw some turbulence to help mix the fuel/air some more. I came up with this idea back in early high school, before I started tearing engines apart, so go figure :PLast edited by pocket-rocket; 08-01-2008, 03:06 PM.-60v6's 2nd Jon M.
