Running a Z24 92 on a dirt track. Only have a little cam (420-443) installed.
Also running a lite flywheel. I have just remark that the spark plug seem to run on the lean side!!
We are most of the time full throttle. also running a fuel pump from MSD at 40 psi.
What is the flow rate from the original injector and what size can i go to before having to change a lot of other things.( rules is stock or almost.!!!!)
