Alright guys I'm starting a slightly different project and I need some help. I'm building an airboat and want to use a 3.4 I have lying around. The goal is to make as much low rpm power and torque as I can the biggest set back being this will be a carbed motor as electronics aren't the way to go when you're running around in the swamp.
As it sits the motor is stock with a tbi intake that mas in my s-10 before I swapped in a small block. I have a brand new set of 3400 alum. heads that I bought for a top end swap again before I swapped motors, so those are lying around as well. Can I swap the heads build an intake, stab a distributor in it and make it go? Obviously I doubt it's that simple so tell what you think. Any help would be much appreciated! Thanks
