Your going to keep the rest of the springs after than happened?
He likes to gamble..
it's gotta be running for the V6 bash, that's why we're pushing so hard. poor guy pulled his stock 3400 and stuck in the built one.. it spun #4 rod bearing after a few minutes ( the block is cursed).. so he had to pull it again and put the cam and P&P'd top end on his first 3400.. now it breaks a spring.
ouch yeah cant say any of mine look like that. last time i saw mine they looked normal.
i found this awhile back dont know if id totally trust them to 550 but 500 they should live for awhile.
GM LS6 Valve Springs
Designed for lifts up to .550" with less aggressive ramps!
For springs designed for more aggressive camshafts take a look at the Comp Cams 918 Springs or the Precision Race Components Double Spring Kit!
sigpic 99 Grand Am GT 3400/3500 -Solid trans mount--TCE 65mm T-body---85mm LS2 maf---1 1/4' TCE intake spacers with 3400 upper--SLP Catback with flowmaster 80--TOG headers
Modded 3400 lifters with LT1 springs---Comp Cams 26986 Springs 1357 cam 227 233 .050 dur 515 515 lift 112 lsa
i went the race track sunday(9 days ago) and ran a personal best, 14.71, with a stock 3400 in my bird.... went home, ahd the motor out that night, and from there everything sucks :P swapped it, blew it up, pulled it again, swapped parts, dropped it in, broke a spring, got a new one from GM(had the blue "Made in Germany" tag on it), put that in tonight.... it has a gross-sounding top end clack also.... so tomorrow i get to pull the timing cover and make sure the cam bolt it tight.... because we checked all the rockers, that's when we found the spring, we were searching for a misfire. Misfire's gone but it's waaayyy to noisy... so i'm doing that tomorrow.... man..... what a week.... add in my GF breaking up with me and kicking me out of the house, and i stopped having a good time last monday night
