3500 Tune?
  • 3500 Tune?
    Okay, I really need to know if there's a tune for a 3500 that isn't ridiculously expensive, or a one-way deal (send in your PCM, we send it back kind of BS). Any chips? Anyone try a chip for a 3400 or 3100 (are there any)? What about programming myself? What do I have to have?
    check www.g6performance.com there are a few new OBD2 tunes for the 3500, not sure on gains though..
      Yeah, both of their tunes are "pay for our tuned PCM and we'll send you one for $500 with a $250 core of course, oh and we don't want your PCM because you're a Malibu, so just send us $750, but we can't guarantee anything". Gains are AWESOME from what I hear though.
        gains from ECM tuning on a stock engine are usually like 5-10 HP unless they're starting with a terrible tune. I know for a fact that a stock LX9 3500 when propperly tuned will make an easy 225 crank HP.. may be more. But that's on a fully mapped OBD1 computer.
        a 3500 swapped beretta with a set of headers and an auto tranny just ran a 13.96, that's about 230 WHP/260 crank HP.
          Er, yeah my bad, that is his latest time.. Disregard LOL
            You don't use chips on these pcms. Only on the older obd1 computers. All the new stuff has flash programmable memory. You can load a new program into the computer as many times as you want, as long as you have a programmer for it. The only tuner available I know of only goes up to '04 cars with 3400's though. Nothing I know of for the 3500, or for the newer CAN based systems.
            '97 Grand Prix GT 3800 (sold)
            Gotta love boost!
              There is the 04 3500, which does not use the CAN system. It's where some of the tables came from that I am using.
              SpudFiles
              Theopia
              Enjoy life online.
                what ECM was ran with that 3500/OBD1 setup? maybe darthfiero(ryan) can look over the tables and modify them for my engine. then i could have a sooner running LX9 Fiero GT!
                ENGINE HAS INTERNAL DAMAGE. THIS MOTOR WILL BE TAKEN OUT OF THE FIERO AND REPAIRED IN TIME. UNTIL THEN, A L67 WILL RESIDE IN ITS PLACE
                87 fiero gt 5spd 3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe, 2.5 inch ex, flowtech muff, 7730 ecm, moates.net APU1, self tuning *learning* (GOT FROM MY BROTHER, divorce reasons.)
                  The stock beretta 92 ECM. Aslyum is the one with the car. It's a blue beretta. You have a cam though so you'd need more tuning.
                    You would be better off having someone that knows these computers and engines tune it. GMtuners doesn't have the best track record with obd1 3400 and the 3500 won't be any different.
                      well maybe i can get that tune to have it modified to work with my cam, headers, TB, and P&P
                      i cant find anything for Aslyum.
                        Here I am, LOL
                        Mine is running on the stock OBD-1 ECM, however it has a VERY modified chip.
                        It was tuned on a Moates Ostrich thingy, that quite frankly I know nothing about.
                        I don't know if Rodney is on this Forum, but you can find him at "3400Beretta" on Berettastuff. He's the guy who makes this thing run.
                        Or contact "superdave" on here.
                        He has a similar set up to yours (sort of) and is making alot more power than mine does.
                          are you running the 7730?
                          i have the moates APU1. and i know nothing about tuning as well. i can burn a chip and swap between tunes while its running though. bout it.
                          ill contact him and hopefully he can help me out.
                          ive talked to superdave (or maybe it was just his name i saw up there a bit) a lil bit about this and other things for my motor.
                            yes he has the 7730 ECM.
                              anyway i could possibly get this tune to try and see how it works and then tweak it to work for my car?
