What year/model car can I find a solid-core roller cam? I'm having a custom grind done by delta.
Where to find roller core??
3.4 block converted to roller valvetrain with 220/225 cam on 115 lsa, '769' heads with 3500 valves, LS6 springs & porting, twin T04E turbos, 3500 plenum with ported 3400 lower & 'short star' 65mm throttle.Tags: None
Originally posted by 85maro View PostWhat year/model car can I find a solid-core roller cam? I'm having a custom grind done by delta.
then click on stock cams on the bottom and itll tell u what cam goes with what sensor, they are the same as opposed to cam journal dia and such so they will all fit in any block, but you need to keep the sensor/cam together
It's a rwd 3.4 block. The cam sensor's only going to serve as a plug for now, but I do plan on keeping it in case I ever decide to step up to sfi. So who's ben? I don't frequent this site much anymore.Increasingly I find the difference between a "fact" and an opinion is the number of people who believe it.
Yep. What do you charge for regrinds?Increasingly I find the difference between a "fact" and an opinion is the number of people who believe it.
cam sensors to cams don't matter, I just ordered my cam as a cam, never told Ben what sensor I had, I'm currently running a 05 sensor on a 97 ECM with a who knows what style cam cutout...
Its a HAL effect sensor... Leading edge, they all reside in the same spot so it knows were #1 is opening the intake.
I've used various year cams on various year sensors and various year ecm's, for example my 00+ 3400 was running with a 94 sensor in it... NEVER threw a code once and my SFI always worked... since yeah it would throw a code if the cam didn't agree with the crank.
