TBH, I have never had problems unbolting any exhaust on any of the 60v6's. Never had stud 1 break or anything. Now Fords.... unless you have a torch handy, forget it. But yeah, GM's exhaust studs/nuts have always worked out great for me without having to heat them up.
about rockers
headers? hell yes! min of 15 hp gain there! really woke up my GASE. you can look for used headers on grandamgt.com . got mine there with the cat for $460.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Originally posted by pocket-rocket View PostTBH, I have never had problems unbolting any exhaust on any of the 60v6's. Never had stud 1 break or anything. Now Fords.... unless you have a torch handy, forget it. But yeah, GM's exhaust studs/nuts have always worked out great for me without having to heat them up.
I have a problem I can't get to the bottom of concerning rockers. I put a set of CompCams 1.52 rockers on my hybrid 3.1 (see signature) and it has had a serious idle problem since. I've checked for vacuum leaks, reset the the IAC, replaced the IAC, checked the TPS voltage and still it won't idle right and it will surge at part throttle and idle way up to 2000 intermittently, all since I changed the rockers. I also readjusted the rockers. I am of the assumption that with my cam profile and what little addition to the lift the rockers may or may not have created that it's making the ECM go ape-shit. I'm at the end of my rope, ideas please??? (204-214@.050, 270-280 adv., lift-.420, .443, 107-117 centers). It ran fine before the installation of the rockers with one problem during installation,a push rod slipped off a rocker and bent causing the valve to stick open and backfire. It only ran like this for 20 seconds before I shut it down.Last edited by Ray Hamilton; 05-19-2008, 12:51 PM.'86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
Originally posted by Ray Hamilton View PostI have a problem I can't get to the bottom of concerning rockers. I put a set of CompCams 1.52 rockers on my hybrid 3.1 (see signature) and it has had a serious idle problem since. I've checked for vacuum leaks, reset the the IAC, replaced the IAC, checked the TPS voltage and still it won't idle right and it will surge at part throttle and idle way up to 2000 intermittently, all since I changed the rockers. I also readjusted the rockers. I am of the assumption that with my cam profile and what little addition to the lift the rockers may or may not have created that it's making the ECM go ape-shit. I'm at the end of my rope, ideas please??? (204-214@.050, 270-280 adv., lift-.420, .443, 107-117 centers). It ran fine before the installation of the rockers with one problem during installation,a push rod slipped off a rocker and bent causing the valve to stick open and backfire. It only ran like this for 20 seconds before I shut it down.
Not that you want to do this, but have you thought about swapping back to the old rockers and seeing if the issue is still there? I just find it hard to believe that going from (I'm assuming) 1.5 to 1.6 ratio is going to cause the ECM that many issues.-Brad-
why would you change to a smaller ratio and go with the roller tips instead of staying with the stock 1.6 ratio and roller fulcrums?
maybe you bent a pushrod.Andy
Actually it's 1.5 to 1.5. The next thing is to switch back as you said. Today I put on a different TPS and reset it to .51. Things seem better. How long does it take for the ECM to "learn" the new settings? Thanks for the reply.'86 S10 Blazer 4WD, '87 2.8 with 3.1 crank and pistons, A.R.I. "Stage 2 Cam", Iron Heads with stiffer springs, Holley TBI, Manifold bored to fit the TBI Base(4.3 size), Fiero Covers, MSD Coil, DynoMax Muffler and 2.5 Tailpipe, no cat, Auburn Limited Slip, 3.73 final Drive. 700R. '85 Fiero GT 3.4 Hybrid, relieved top intake and exhaust, 57mm TB, Auto. 3.06 final drive.
oops. my bad! should have read your sig like you suggested. i just read hybrid and assumed it was a 3.1 alum head.Andy
Originally posted by pocket-rocket View PostTBH, I have never had problems unbolting any exhaust on any of the 60v6's. Never had stud 1 break or anything. Now Fords.... unless you have a torch handy, forget it. But yeah, GM's exhaust studs/nuts have always worked out great for me without having to heat them up.You may or may not know 10 times what i do.
Looking at a 95 grand am 3100, how the hell do you get the bolt off the heatshield that is right behind the trans dipstick tube? Do you have to take the dipstick out?!sigpicNew 2010 project (click image)
