if mating a LX4 to a 5speed what flywheel do you use would any neutral balance from the 2.8-3.4 work?
3500 LX4 Flywheel
Well you still need neutral balance. Not sure what will bolt up and work though... Probably any 2.8/3.1 FWD mpfi fly wheel.sigpicNew 2010 project (click image)
yes the fwd 2.8/3.1 flywheel
look at an 88 fiero, 88-92 cavalier, berretta, etc etc3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
2012 Chevy Sonic Turbo 6spd
the difference could be the balance3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
