Originally posted by Canyonero
View Post
Improving Engine Efficiency & Performance
Originally posted by betterthanyou View PostHa ha I hear you man. I just went 4 wheeling yesterday and on the highway doing 100Km/h (60mph) I was at 3000RPM but the throttle angle wasn't very high. However I have got to get that 2.8L out of there. I couldn't pull any kind of hill in 5th. No torque!). Mileage is looking improved. Same or better than I was getting with my 2.8L. I'm going to finish up the tank with my usual mixed semi-rural driving an see what happens.
I've been researching and experimenting for a while to bump up fuel economy, and the one thing that helped big time was advancing the ignition timing on the highway. This engine would not get above 23 mpg when commuting to work, which is about 80% highway (going 70+mph). Light load, cruise speeds had about 40 degrees advance stock, I'd calculate between 21-23mpg. I bumped this up to 46-48 degrees and now the car has consistently averaged 24-26 mpg. Granted there's many variables but I have NEVER been able to hit 25+mpg territory before.
My cam has a LOT of valve overlap, I calculated 43 degrees. This may allow me to run higher timing #'s especially if I'm getting a natural EGR which I think I have. However this extreme duration may be detrimental to my fuel economy to begin with.
Getting back to what was mentioned earlier how it's ideal to have your peak torque at around cruising speed, I recently read an article about Oldsmobile in the late 1960's producing a Cutlass Supreme "Turnpike Cruiser". The engine was a standard 400ci Olds engine only with a special camshaft with smaller-duration and advanced timing. Coupled with something like a 2.55:1 rear they were able to increase fuel economy from the mid-teens to the mid 20's. Link to the article HereLast edited by Rhedalert; 04-29-2008, 12:50 PM.Brian
3400 SFI V6, 4T60e
Finally thank you Brian for some meaningful input to this otherwise worthless thread of rambling. Too bad I missed you I was at Larry's helping him move over the weekend. Guess you are just going to have to join us out at Island Dragway soon! Take care.
Ken2004 Black Cobra Vert
New Best Time 9-2-07: 1.81 60' 12.06 @ 117.3 Mph
455 rwhp/ 458 rwtq
1988 Pontiac Grand Prix SE - New Setup: Stock 3400 with 52 k on it from a 05 Impala, 255 walbro, LC-1 WB, Spec 3 Clutch, CS144 Alternator upgrade, DIY tune
1989 Pontiac Turbo Grand prix - 44 k original miles, birchtrax'ed & intrax'ed, crane 2020, Topgun 160 +++ my own special herbs and spices
Originally posted by SappySE107 View Posthttp://youtube.com/watch?v=f5xXBb_mrYc
If you make it all 36 minutes, congratsInteresting but could have been 1 minute and more details on how to do it.
The part about his dads '41 Cadillac a the dog was great too... and the part about liquid nitrogen cooling the exhaust...too funny
Nice to see our tax dollars going twords something useful...Last edited by Bones; 05-01-2008, 07:59 PM.
Originally posted by SappySE107 View PostYes, it takes all kinds. Now that you are here, i suggest learning a bit before sharing your uneducated comments.
you ever turn an engine over by hand without the spark plugs in? try spinning it at 500 rpm manually. too much work and can't do it huh? hmmm....no pressure still built up after combustion since YOU are doing the work. that means there is a lot of friction there. that's why an internal combustion engine is so inefficient. not to mention the fact that is has to overcome compression forces.
wow! "NEVER never going to be a revolutionary improvement in efficiency." soooo since the eairly 1900's, the engine has seen no improvement? variable cams including lift and duration (electronically controlled), variable intakes, EFI, computer designed camshafts, ceramic coatings, anti-friction coatings, more efficient flowing exhaust systems (metal catalytic converters) , direct injection, turbos, lower friction synthetic motor oils in thinner viscosities, and there has even been a running concept of a variable compression engine. with more research and technology involved, compression ratios have been rising making the engine more efficient alone.
initially, i did think SappySE107's comment of sharing uneducated comments was a little harsh. however i'd say that i have to agree with him 150%!! please research first.Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
Actually in the mid 70s when the emissions situation hit, compression ratios took a nosedive. Back in the muscle car era it was nothing to have a compression ratio in the double digits up until the switch to unleaded gas. I read about a Camaro that came with 12.0:1 compression stock. Cars today stock haven't hit that mark either. Not the 08 Z06, Viper, or the Enzo.-60v6's 2nd Jon M.
I guess he skipped the part on direct injection and the higher compression possible from 2 pistons moving at each other vs 1 piston moving against the cylinder head. Frictional losses increase with RPM, so the more you have to spin the motor to make more hp, the more you lose. The crank spins on a thin layer of oil. Most of your friction comes from the rings and piston in the bore, not the rotating assembly.
At 7k, you lose roughly 56hp on a 3400 due to frictional losses (according to dynomation 5). While there are multiple areas to address to increase efficiency, the friction loss is more significant than you think.Ben
Originally posted by torq455 View Postyou ever turn an engine over by hand without the spark plugs in? try spinning it at 500 rpm manually. too much work and can't do it huh? hmmm....no pressure still built up after combustion since YOU are doing the work. that means there is a lot of friction there. that's why an internal combustion engine is so inefficient. not to mention the fact that is has to overcome compression forces.
Internal combustion engines make power by turning chemical energy stored in the fuel into heat energy, which is then turned into mechanical energy. So any heat energy that dissipates into the atmosphere without being turned into mechanical energy is considered waste. That includes heat that goes out the exhaust, heat from the radiator, the block, etc. In thermodynamic terms it's all wasted energy.
I'm not saying that there haven't been improvements or that there won't be more improvements in the future, but those improvements tend to be evolutionary rather than revolutionary. The only exception that I can think of is the Crower 6-stroke engine which is an attempt to reclaim the energy that is normaly wasted through the radiator.
Anyway, we all know what they say about arguing on the internet...
Originally posted by SappySE107 View PostI guess he skipped the part on direct injection and the higher compression possible from 2 pistons moving at each other vs 1 piston moving against the cylinder head.
edit: next you'll try to convince me that his "electric supercharge" is a valid technology?I'm not trying to be an argumentative dickhead, but all the ideas this guy is trying to sell are bunk. you could probably dig up thousands of old patents for ideas just like these.
So the cylinder head doesn't absorb any heat energy? Right. And 2 pistons moving at each other is a gimmick? Only because you don't understand or have any desire to open your mind to concepts you haven't heard before.
pumping losses are 10hp at 7k and frictional is 56hp. Thats through simulation software, which is based on a lot of real world testing and math. Please provide some proof of your claim that pumping losses are greater than friction. So far you are only concerning yourself with thermal losses.Ben
