First off I have to give a huge thank you to Oldskoolgp, Josh, for all of his help in getting the Sunbird going again, I couldn't have done it without him. I also have to thank Ben for his great service, and helping to resolve the valvetrain issue I had last fall. I can't wait to break this motor in right, and get it to the track!
Even though we don't have the headers done quite yet (soon I hope, they only need "tweaking" and coating), we got the stock exhaust hooked up, and actually fired up and drove the car today! Besides having major alignment issues, a coolant leak that we fixed, and a small oil leak from where an engine oil cooler would be plumbed in (which will be fixed with some teflon tape soon), everything went great. The new motor fired up after only 2-3 seconds of cranking. We managed to properly break-in the cam and valvetrain, and everything seems to be working well. We did get a check engine code which may be EGR related. I bet that once I get down to see Ben in Indiana, he will be able to tune out the minor bugs (I'll be in touch to try to schedule a day for a road trip from WI). The car should be street drivable by end of week, and hopefully fully race-ready by 1st of June.
Here's the specifics on my NA Gen II 3.1MPFI on steroids:
1990 3.1 block out of Pontiac 6000 bored .060 over
Reconditioned stock crank and connecting rods (balanced rotating assembly) w/ARP Rod Bolts
Silvolite Hypereutectic skirt coated pistons (pn 1496c)
Hastings rings (moly-face top ring)
Crane 272 cam
Short block built by Bailey Motor Sports, Sun Prairie WI
62mm FDP TB
200cc Injectors (21 lb ?) from 2001 3400 SFI with Gen II rails and spliced harness (thanks Tye!)
Gen II Heads & Intakes ported & polished by Ben from WOT Tech (thanks Ben!)
LS6 valve springs
Comp Cams 1.52 roller rockers
Newer style valves
Custom burned temp chip by Ben from WOT Tech, custom tuning to follow from Ben
Centerforce Dual Friction clutch
2 1/2" custom exhaust by Matt
Currently stock manifolds and downpipe to be replaced by custom headers once finished and coated, 1 5/8" primaries, into 2" collector, into 2 1/2" exhaust
With the tired factory original motor with 152K miles on it, and 928 1/4 mile passes since 1993, it ran 15.453 @ 89.76 mph last April (2.086 60 ft on BFG g-Force DRs, 1/8 mile timing lights down on that run, but 6.318 @ 330 ft & 12.887 @ 1000 ft). Any guesses on what the fresh mill and clutch above will do? I am shooting for 14.25 @ about 100 mph. Who knows, with good air and traction, I hope to flirt with extremely high 13s. I hope to go where very few NA Gen IIs have ever gone before. Can't wait to post some scanned slips once I get her to the strip in a few weeks. I really look forward to cool fall air, after I put some more miles on the mill, for some hopefully very impressive numbers. No offense to you fast and successful Hybrid folks out there, but I want to see what I can do "old school." If I'm not happy with the results, I can always go hybrid too (but hope I won't have to anytime soon, this was VERY EXPENSIVE, don't recommend this approach to those on budget, go hybrid instead!)
Crane 272 cam
62mm FDP TB
LS6 valve springs
Newer style valves
