Yep, thats right. The Crane gold race roller rockers in my 3400 are going bad. I'm doing some maintenance on the car and decided to pull the front valve cover off to check them, because they seemed to be getting louder with time. Wasn't sure if it was my imagination or not. So I'm looking over them with a work light and I see this...
All kinds of little metal shavings inside the edge of the fulcrum bearing. Wiped it with a paper towel and came away with this.
Lots of little speckles. About half of them on the front seem to have this, and they seem like they might have a little too much side to side play in them. Hard to tell since they are floating rockers with guide plates. Anyway, I sent an oil sample in to blackstone labs for analysis on saturday, and I should find out the results on tuesday or wednesday. I'm sure they're going to find a lot of something though.
So it appears I'm going to be tearing the top of the engine apart and going back to the stock rockers and pushrods for now. I just hope they play well with the cam and valve springs on the engine. I have no idea what could have caused the failure, because it looks like they where getting oil. Maybe they weren't getting enough oil to get it into the drain holes that feed those bearings? Maybe there's a difference in the amount of oil flow with the hydraulic roller lifters in the 3400, compared to the solid lifters in the engine these rockers where actually designed for? Maybe they got too hot, maybe they weren't adjusted properly, maybe god doesn't like me? I got no clue.
!!!!! BOSCH PLUGS RULE !!!!!
because I\'m not Canadian
