My car is right around 3000lb and I don't consider it heavy or light.
Newb wants the basics for performance.
I'll roll mine down to the mill and put it on the truck scale sometime, but published curb weight is just shy of 3800lbs. Mmmm, Japanese SUV.'98 Volvo V90 - Ford 5.0 swap in progress
Hahah yeah. Most new cars are 3400 to 3800 for small to mid-size now days it seems. But older cars were like 2700 or less. My car is lighter than new cars, but heavier than older cars. Get it?sigpicNew 2010 project (click image)
I would go with 2.5". Get a new downpipe made as the stock is double walled and very tiny inside. Get a highflow cat, and a good straight through muffler (dynomax ultraflo, or hooker aerochamber). Mandrel bent pipe if you can.
For exhaust manifolds you could get the 2004 Impala 3400 ones, they are logs but really bigger inside. Also any newer 3x00 exhaust manifolds will have a better rear instead of a log, but you having a 98 might already have the short runner rear manifold.
Headers of course would be best but put you over budget.sigpicNew 2010 project (click image)
Originally posted by IsaacHayes View PostI would go with 2.5". Get a new downpipe made as the stock is double walled and very tiny inside. Get a highflow cat, and a good straight through muffler (dynomax ultraflo, or hooker aerochamber). Mandrel bent pipe if you can.
MagnaFlow manufactures the best exhaust systems, mufflers, pipes and catalytic converters; now being sold directly from our website! We proudly manufacture products in the USA using premium components and the latest technology. Voted 2017 SEMA Manufacturer of the Year!
3100 is 191 cubic inches. Then with performance mods, say big port top end you have around 175hp.
150-200 CID - 100 to 150 HP = 2" to 2-1/4"
200-250 CID - 100 to 200 HP = 2-1/4" to 2-1/2"
According to that we are above the 150hp just being stock. So 2.25" will work, but 2.5" would be best and give you room for later mods like a full 3400 or 3500, cam, whatever. Either will work just fine. Mandrel 2.25" is probably better than crush bent 2.5" though. So Mandrel for the win, and if you can't get mandrel, then go 2.5".
Several people on here have put 2.5" on a STOCK 3100 and said the gains were very good. I plan to go 2.5" sometime. My 3100 I will estimate at least around 175hp since I have the big port intakes, and even better 3500 plenum. I don't have the slightly bigger intake valves but its a very small size difference so I don't know how bad that hurts flow.
2.5" shouldn't be too big and yet still have plenty of room for more power up until 300 or more HP.sigpicNew 2010 project (click image)
