which cam
  • which cam
    im rebuilding a 3.4 off a camaro, its going in to my 86 s10. the only performance mods im thinking of doing is a port & polish job on the heads maybe mil them a bit for a small compression bump. im going to be using a 4.3 TBI setup, can someone help pick a cam that will be street freindly with a nice power incresse.and tell me which ones to stay way from
    s10s ive owned
    87-2dr 2wd blazer 6/7 drop-sold and missed
    82-s10 pickup long bed-sold thank god
    86-2dr 2wd blazer 6in. lift 31" tires-sold
    92-s10 pickup ext cab3.4L-6/7 drop
    crane 272. good power, great economy and sounds like a lumpy cam. easy fo tuning
    how are going about the 4.3 setup? just using the 4.3 tb with injector? most of the 90 degree v6 parts are not interchangable. are you fabricating?
    2012 Chevy Sonic Turbo 6spd
      the 272 is a bit agressive for a daily driver, the H260-2 from Crane is a very nice cam for a DD and easy to tune for.
        Yea the 272 does not have the Idle quality of the 260 but it will make more top end power. John over on S-series used 272 in his 3.1L build and he really liked it.
        Go with either the 260 or 272 cam just decide what suits your needs and application.
          If using a 4.3 tb you need to port or bore the intake since the tb will have a bigger bore. If tearing engine down what about dohc 3.4 pistons for an increase of compression.
            yes im just using the 4.3 tb and injetors bolts right in but the intake needs to be bored like 923.46v mentioned.
            i dont know to much about cam numbers, 260, 272 are duration #s right. what are the pros and cons of both? why is the 272 too agressive for DD.
            s10s ive owned
              both the H260-2 and the H272-2 are Crane cams, the 272 has a bit more valve overlap which causes a nice lopey idle and lower than normal idle vacuum which can effect the power assist brakes. It's not extreme by any means and you certainly could daily drive it with a bumped up idle speed (around 950-1050 RPM)
              If you have an Auto tranny you'll want to pick a different stall converter, something around 2500 should work.. if not the fact that you'll have to bump up the idle for the 272 will cause it to lurch at stoplights and can damage the tranny over time. If you have a 5 speed then you'll be fine.
                yes it has a 700r4. what should one expect to pay for a torque converter like the one you mentioned? will the 260 be fine with the stock coveter.
                im not even sure what a higher stall coverter does, or what lock-up and non-lockup means.
                s10s ive owned
                  the 260 cam would work fine with the stock setup..
                  I picked up a 2800 stall converter for my old Trans Am for like $100 on ebay a few years ago, it was for a TH400 and brand new. Very nice unit.
                  here is some stuff on torque converters.. much better than i could explain it.
                  Cars with an automatic transmission use a device called a torque converter instead of a clutch. So what does a torque converter do?
                    thank you superdave
                    s10s ive owned
                      Hi there!
                      The 260 is almost identical to the 3.4 crate cam, except the LSA is 112 vs. 107 for the crate cam. The 260 should, on paper, have slightly less peak power but a more broad powerband than the crate cam, and again on paper, should be more friendly to the TBI in stock tune. Either would be a good choice for a driver.
                      1982 Chevrolet S-10 Sport, 2.8V6 TBI
                      2006 Pontiac Solstice
                        here are some other cams that would work for you...
                          i had my mind set on the crane h-260-2, but i noticed that the GM cam part # 12364059 has the same number. summit sells the crane cam for $205, gmpartsdirect.com sells theirs for $150. whos would you rather buy?
                          how about valve springs, push rods, timing set. can i use stock replacements or is it really necessary to get crane parts.?
                          s10s ive owned
                            Crane makes those cams for gm but personaly I don't like Crane I'm a Comp man
                              Where can you find the Crane cams at. All I can find is stuff for V8's
                              96' Z26.
