previous gen 3500 intakes compatible with LZE VVT?
  • previous gen 3500 intakes compatible with LZE VVT?
    Are the upper and lower intakes interchangeable between the different 3.5s?
    No, the VVT engine uses a totally different intake setup.
      and the short star is a diff animal....the olds 3.5 dohc
      2012 Chevy Sonic Turbo 6spd
