3500 Valve Diameter
  • 3500 Valve Diameter
    What is the diameter if the 3500 intake and exhaust valves.
    8mm stems, 1.42" exhaust 1.76" intake.
      What are they on a 3400 and a 3.1 mpfi?
        8mm stem, 1.76 intake and 1.42 exhaust for 3400 and 2000+ 3100
        8mm stem, 1.72 intake and 1.42 exhaust for 2.8 and 3.1 and 3100 up to 99
          Since the 3400 and 3500 both have the same valve sizes, is 1 better than the other or 1 flow better than the other 1??
            3500
              arent the 3500's lighter as well?
              2012 Chevy Sonic Turbo 6spd
                I haven't weighed them, but I'm sure if Ben says they are, he did
