  • 3100
    i got a 94 3100 motor and i cant find much as far as after market stuff goes...
    anyone know of anything...
      Pretty much anything that works for a 3400 will work on the 3100. Just keep in mind there are a few small, but easy to overcome differences depending on what you want to do.
      1995 Grand Am SE
        thanks.. i know the 3400 is basicly a bored out 3100 but i didnt know what would bolt up
          so does that mean that some 3500 parts fit as well?
            Yes on the 3500 parts.
              any recomendations?
                  haha.. if only i could
                    Well, you didn't list a price range. You can do a cheaper setup.
                      yea i know.. im just tring to see whats available..
                      thank you by the way
                        whats an easy way to up the cr on a 3100
                          I thought the 3500 top swap wasn't exactly optimal for a 3100?
                          Dual Outlet Exhaust with Resonator Delete, Front STB, Rear STB, GMPP Trailing Arms
                            3500 heads won't clear the bore on the 3100, but you can use the 3500 plenum, if you use a 3400 lower, or 2000+ 3100 lower. On mine I have a 97 3400 lower, and 05 3500 upper.
                              Right it was the bore thing. I just posted that because someone put the link to the full 3500 top swap on here, and it should be clear that it won't work without overboring the 3100. Otherwise what you said will work.
