ok a few questions, i was looking at maybe cutting some rotational weight on the assembly, so i was thinking about cutting the ears off the end caps on the rods, also machining the flat spot on the end cap down and maybe contour the flat spot on the top of the rod as well. what do yall think...?
also the age old question of knife edging the crankshaft...should i do it and how extreme should i go, if you have seen a lunati knife edged crank its not like some that castillo has pictured...input please
