Originally posted by Badassoldspower
View Post
3400 build Plans Finally Complete
Originally posted by sprucegagt View PostI thought it was the DOHC pistons w/ 3500 heads that got you 11.5:1.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
i had to do a little searching before to find it
99 Grand Am GT
What's the "Piston Deck Clearance" dimension? I don't understand were the 0.0095" spec that you used is coming from. I thought 3400 pistons came proud of the block by 0.020". Given how small the spec is it makes me think it's the piston to bore clearance. Am I right?Your local OBDII moderator
2000 Grand Am GT w/ WOT parts
The piston deck clearance should be the distance it comes out of the block. The 0.0095" spec is a value that I think I built into the database prior to the measured value of 0.020". I'm pretty sure I came up with that number by looking through old posts and calculating the value given other piston values. I don't know, its been so long since I created the original program and database entries.-Brad-
Well if that is the piston to deck clearance, then the actual value you would use is -.020. If so then what piston could you use to get 11.5:1 compression without getting custom pistons. I ask because iron head 3.4 pistons get you 12.6:1 and DOHC get 13.4:1 and they aren't exactly streetable w/ pump gas.Your local OBDII moderator
Right. Look at the 3100 default values, and you will see that is what it has. If you use all the same values for volumes as the 3100 (piston dome and combustion chamber), plus the -0.020" value, then you come up with a stock CR for the 3400 of 9.93:1. If you change it to -0.015" (which I think I saw some mention the other day somewhere), it comes out to 9.81:1.
In order to come up with an exact value, you should use actual measured values from your specific components. Depending on porting work and such, CC volume will definately be different.-Brad-
3.4 pistons do not stick out of the block, hence the .040" gaskets on the iron heads.
3500 heads and 3.4 Camaro pistons make 11.5:1 with 3500 gaskets, 3400 gaskets gives 11.75:1 and 3.4 gaskets give 12.33:1. The 3x00 gaskets actually leave a little too much clearance between the heads and pistons, .040" is supposed to be ideal. SI valves will raise it a bit more, too.
Hey Ben, did you use the cam do bring down the CR? Would you mind sharing details of the tune if you used OBD1? My new combo for my car isn't going to be too far off from the one you built.
EDIT: What is the DOHC piston to deck clearance?
Originally posted by bszopi View PostIn order to come up with an exact value, you should use actual measured values from your specific components. Depending on porting work and such, CC volume will definately be different.
Originally posted by ForcedFirebird View Post3.4 pistons do not stick out of the block, hence the .040" gaskets on the iron heads.
EDIT: What is the DOHC piston to deck clearance?Your local OBDII moderator
3500 gaskets have a 3.80" bore and the 3400 gaskets have 3.75", both are .060" compressed height. The 3.4 gaskets also have a 3.75" bore.
Remember the 3.4 pistons have a .0095" deck clearance.
EDIT: Sorry, I fogot to use the 3400 gasket ht, 3400 gaskets and 3.4 pistons make 11.56:1
Are you using the 3500's 32.4cc chambers?Last edited by ForcedFirebird; 02-03-2008, 02:15 AM.
Originally posted by sprucegagt View PostNow that matches what I got.
I'm using 3500 heads but they have been milled .010, so chamber volume has dropped a little. How much I don't know.-Brad-
