Are there any differences besides the Egr between the 99 UIM on my Grand Am and a 2000 manifold from an Olds Alero? I want to put the 99 manifold on the Alero but I want to make sure it will flow the same. The Alero feels a little faster and I just want to be sure thats not why.
Does the UIM on my 99 GA flow the same as a 2000?
the kneck is more restrictive as i found out on the 99. the 00+ is more open and does not have the restriction that the pre 99 has.
right between the first runners theres a shelf inside the plenum, where as on the 00+ it is not there and more open.
i found this out after porting it to 65mm.
ill post a pic in a min to show you
99 Grand Am GT
Hahha swapping parts from the wifes car?
I doubt that little bit is noticeable. If you want something good that you might feel grab a 3500 plenum, and larger TB. A little more involved but it's the best you can put on.sigpic New 2010 project (click image)
i dont have a direct through the kneck shot but just looking in its like half the size.
plus with the 00+ you dont have that shelf, the air just flows in.sigpic
99 Grand Am GT
Hmm, I guess it's more restrictive than I can see. Has anyone swapped this only and felt a difference in the butt-dyno?sigpic New 2010 project (click image)
ive had both on my car with the current engine, only cause the upper that came with the motor had a crack so i had to swap back to the 99 setup till i got a new manifold.
but thats when i started with dhp so i honestly couldnt tell you.
Ben how much less does the 99 one flow.sigpic
99 Grand Am GT
Originally posted by IsaacHayes View PostHahha swapping parts from the wifes car?
