Thanks for the tip..didn't think about adding a cowl by itself. So 12 in. huh? So if I made a top half then I wouldn't need to mess with the egr setup? So 12 inches above that. That actaully seems very doable. Then a cowl to boot. Hmmm. By Goerge mate that awfully keen! :P
Technical Theory : Plenum Design
The EGR is on the top half, so yeah... you would have to mess with it.-Brad-
Slowly making progress on my UIM. It still needs the end cap made and the final welding.
MarcMinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
http://www.tcemotorsports.com
The TB is from a 5.3l Chevy truck... 75mm.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
Thanks Colin... Im hoping it improves performance as much as it does the looks.I still need to port the heads, add LS1 springs, get a cam and make the billet valve covers. Have not decided on whather to rebuild the short block as it has 52k on it. Its a slow process since I dont have alot of money/time to put in it.
'79 MGB - LZ9 - T5
Originally posted by 93vinxthat tb looks like it would bolt up to a stock 3.4 96 plenum, any one else? what do you think cnc guy?
I dont know what effect this manifold will have but it should flow more than the stock one. I am sure of one thing, the modded 3400 should have considerably more power than the stock 3100 thats in it now.
'79 MGB - LZ9 - T5
Originally posted by CNCguyOriginally posted by 93vinxthat tb looks like it would bolt up to a stock 3.4 96 plenum, any one else? what do you think cnc guy?
MarcColin
Originally posted by 93vinxi was referrring to the dohc, wil it bolt up? 75 sounds like a nice middle range number not to big or too small, i wonder on the availablity,
I got the 75mm TB with IAC & TPS came from ebay for $25 & 10 shipping.MinusOne - 3100 - 4T60E
'79 MGB - LZ9 - T5
