i have a 4t60e 6wfw i want to swap the drive and driven gears so that i can get a 3.69 fdr. my diff is 3.29. so i was wondering how hard it is and how much stuff i will have to remove to get to them? i am hoping to just lower the engine out throught the bottom of the engine bay and remove the side plate on the trani and work on it leaving it attached to the engine. is that possible??
4t60e drive and driven sprocket change?
1996 Beretta
3100 SFI TURBO
13.1 @ 103 mph best in the 1/4 mileTags: None
