A stuck-open injector, or a blown fuel-pressure regulator diaphragm would cause a massively rich condition and fuel in the oil due to leakage past the rings.
Fuel in the oil for whatever reason, will cause a rich condition, even if the fuel got in there by "mysterious" reasons not related to injectors or FPR. The fuel vaporizes out of the oil at operating temps and goes through the crankcase vent into the intake. Could be injectors leaking down, but would there be THAT much fuel staying in the rail after shutoff?
I had a customer's car where someone put fuel in the oil as an act of sabotage and the first symptom was a rich condition that progressed as the engine warmed up, and eventually would stall out.
Never give up. No matter how bad things seem; never give up. Sometimes no matter how meticulously you cross every "T" and dot every "i" something bad happens.
When I was about 18 I bought a car with a (supposedly) good 2.8. While I did nothing as complex as your setup; I did rebuild the carb, alt., buy new radiator, and spent several days getting the engine generally roadworthy.
I changed the oil, filled the new radiator, and warmed up the engine. It took a lot of water, but I finally was able to see the water circulate in the radiator.
Before I could get out of the shop yard, the engine seized up because most of the water went into the oil. The engine had frozen and had a cracked block inside the vee. Had to get another core to build. Installed a 3.1 crank and pistons and got better heads, though.
Later I installed a new-old-stock Rajay turbo. It ran for a long time then the turbo started to make a strange noise. Earlier that week I had installed headlight relays and drilled a hole in a bracket. The drill bit broke off and the hot tip of the bit landed on the cold-air intake. It melted through and sucked into the turbo. Runied the turbo and could not get it repaired. Had to get a modern turbo and re-fabricate the whole setup. New turbo is properly sized; water cooled ceramic bearing unit. It turned the car into a 300 HP terror.
Each time I had to take apart my motor, a way to improve it came available. All is well that ends well. Never give up!
Later,
David
Later,
David
