Well I never started a thread over here because its mostly a Beretta thing, but I have taken on a new project.
It consists of removing a stock 96 3100 from a Rust free 96 beretta base, putting that motor in my red 95 and then taking my Hybrid and putting a larger cam in it, with better springs, some more port work, and possibly a 3500 upper plenum and then droping that in the 96. Also the 96 trans will get rebuilt, with all my normal tweaks I did to the 94 I currently drive, along with a Yank Performance 3k stall converter. Gear ratio will be the 1.12:1 chain combo to underdrive the trans, and then the 3.05 diff with the EP LSD, resulting in a 3.42 FDR... Little more agressive than my 3.33 but still conservative in comparison to a 3.73
Other toys in store for this car is brand new KYB's and Eibach springs, modified J-body poly front control arm bushings Z26 rear axle with internal sway bar and 26mm external addco piggie backed.. I'm gonna test this with the stock front to see if it has a tad more over steer rather than pushing... Also its getting N-body knuckles, bearings, outer CV's and brake setup... I may jump to the F-body stuff but not right away.
Now the car itself is getting a Z26 Body kit treatment, since its a Base, and will also be getting a fresh coat if its FACTORY color... The reason I'm keeping it factory is because its a Rare color for the year, Only 1,455 produced so I'll keep that aspect of it. It will also be getting my Walbro fuel pump, gauge pillar and gauges, full cluster, Z26 seats if all works out, And the blue nitrous bottle in the trunk. Stereo will stay stock since I want the tunes in my Daily Driver over this car, since it will be a toy.
Here are some pics of the car and parts piles I got going on already.
N-body Setup's and the Z rear axle
Z26 Fog setup installed and awaiting bumper.
Z26 Parts
Z26 Parts
