My Long Block Build is Complete!
  • Originally posted by SappySE107 View Post
    Easy test, put the lifter on the base of the lobe (no lift) and install a pushrod. See how much preload you get (tighten the rocker till the pushrod just spin, no slop, and anything past that is preload).
    Thanks. What tool do I use to measure preload? Can you explain it again a little more specific. I kinda understand it and yet i'm kinda confused. TIA
    Do you think it is possible that after they did their measurements that they got the specs of a stock pushrod? Or is their no way in hell? This I want to know. Thanks
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    • Originally posted by blackbombshell95 View Post
      That could happen if the base circle of the cam wasn't changed during the re-grind, but is highly unlikely with lobe modification.
      • Just tell me how much you turn the rocker arm bolt from the point that it is keeping the pushrod in line and the pushrod spins, to having the rocker arm bolt tight.
        • Originally posted by ForcedFirebird View Post
          I need to know for sure. I am going to try and a local friend come out and take the measurements unless i get real specific details on how to.
            Tight as in to snug or to where I can't move the bolt with a wrench? You want to know how many turns I can turn it?
            • When I had my regrind, I bought a testing pushrod a couple years later (had run stock pushrods) and I came up with the same stock measurements, oddly enough. Of course, I had other issues after I measured and never ran that engine again. But I thought it was strange as well to come up with the same length.
              Of course, I'm Polish, so I probably screwed something up somewhere along the line.
              • That is a small sign of possible relief. Thanks
                • IIRC GM adds extra preload stock so you're probably fine... never hurts to measure twice though.
                  BTW, your machine shop does have access to the stock length of the pushrods. I forget what the program's called but it's got specs for everything for almost all GM's engines. I looked up several things about my 3500 on it.
                  • Yeah, i know they got access. But they said they never looked up the specs of stock when they got the measurements for the chrome moly pushrods.
                    • I'll get these photos to my picture gallery after brad fixes Ben's mistakes lol.
                      Thank you farnsworth for these valve covers.
                      • WOW, I would be too scared to put those on my car!
                        Chromed or polished??? If they are polished thats by far the best job I have seen
                        • My God...
                          Brian
                          3400 SFI V6, 4T60e
                          • nice covers those look pretty good
                            what did he use to get them like that
                            99 Grand Am GT
                            1357 cam 227 233 .050 dur
                            515 515 lift 112 lsa
                            • sorry, i'd have to frame them and hang em up in my living room!!! i've spent a lot of time polishing my old GTO's alternator. i'm proud of it, but it certianly doesn't hold a candle to those rockers holy shhl.lpppp!!!!!
                              Andy
                              fastest 1/8: 10.19@ 67.17
                              fastest 1/4: 16.16@ 82.70
                              • Need a couple more pics...
