The end results in the polished and chromed looking identical? Or similiar?
My Long Block Build is Complete!
Originally posted by 3400-95-Modified View PostTo answer your question, I went with a custom cam, Intake lobe from the 1280 and the exhaust from the 1331
216/240 278/289 .517/.568 113 ICL 114 LSA
Hopefully a good monster for what I want.
-=ЯoB=- 3400 3spd Z24 ---167Hp, 193Ft-Lbs @ the wheels
14.99@91.33mph
Originally posted by blackbombshell95 View PostThe end results in the polished and chromed looking identical? Or similiar?
Originally posted by blackbombshell95 View PostThe end results in the polished and chromed looking identical? Or similiar?& it just looks better.
They look even better up close. Since these, the process has been perfected and they come out even better. Here's what they looked like when started...
and after the whire brush...
Originally posted by blackbombshell95 View PostCool. Jason Farnsworth is doing mine. $40 a valve cover
Here you have it guys. This is what I paid for my Performance 3400 short block including the installing of WOT-Tech Street/strip heads and valvetrain with correct length moly pushrods.
One note on the quote is the Cam they had grinded by schneider. I sold that grind and went with a WOT-Tech 1357 Cam.
Be prepared to drop your Jaw. This doesn't include what It cost me to have the heads ported and the cost of the valvetrain. All they did was install and clearance the heads.
New Compression and Cubic Inch
Initial Spin Specs, Bobweight Card, and Final Spin
Sonic Check Specs
Complete 3400 RECEIPT part #1
Complete 3400 Receipt part #2
To chrome aluminum you need to plate it with nickel first. Usually copper, then nickel, then chrome. Don't know about the back side of the cover, if that is not smooth and prepped then it might flake which would be bad inside a motor. No idea how cast aluminum would take either. I'm guessing Ok if you got it smooth enough. Chrome will have a bit more bluer or darker tint to it than polished aluminum.
Just get some good high temp clear so it doesn't yellow and coat em nicely after polish.sigpicNew 2010 project (click image)
Originally posted by IsaacHayes View PostNo idea how cast aluminum would take either. I'm guessing Ok if you got it smooth enough. Chrome will have a bit more bluer or darker tint to it than polished aluminum.Lifting my front wheels, one jack at a time.
Originally posted by 1988GTU View PostYou paid in cash? Are you a dope slinger? Who pays cash beyond 2000.00 let alone what you paid!?!?!
Oh yea, one last thing... Can I have a few G's? You evidently have money in the bank.
Didn't you know that Cash is the only way to do business :P.
That shop takes Cash and Checks ONLY.
Originally posted by blackbombshell95 View PostThat shop takes Cash and Checks ONLY.
