My Long Block Build is Complete!
  • My Long Block Build is Complete!
    Mods are the following:
    Shortblock build performed by AUBURN AUTO MACHINE
    WOT-Tech Crank scraper
    WOT-Tech ARP rod bolts
    WOT-Tech ARP head bolts
    WOT-Tech CAM 1357 CAM
    227 intake, 233 exhaust @ .515 lift and 114 LSA (wot-tech 1357 CAM)
    chrome moly pushrods
    Knifed edged crank
    shot peended rods/polished
    WOT-Tech MLS headgasket .060 stock size
    Block Bored .030 over
    11:1 fully coated Forged Ross Pistons .030 oversized
    Stock Crank Balancer
    WOT-Tech double roller
    3400 aluminum Heads and valvetrain from 60degv6.com/store
    WOT-Tech Street/strip HEADS
    flowmatched ports.
    CC matched
    SI valves
    LS2 springs with ls1 shims, cavalier seals.
    WOT-Tech Modified Crane Gold Series 1.6 rockers to clear LIM.
    NGK spark plugs 2 stages colder
    Intake manifolds
    WOT-Tech Ported lower intake manifold
    The lower intake manifold and rockers were both modified for proper rocker arm clearance. (Modified by Ben)
    WOT-Tech Ported upper intake manifold with 65MM TB Opening
    WOT-Tech phelonic intake spacers
    WOT-Tech EGR Blockoff
    Throttlebody
    WOT-Tech 65mm Billet TB
    Transmission
    Being built now by Engineered Performance
    LSD
    Furnace braced TQ
    3k stall
    3.73 gears
    Energy Suspension Transmission mount
    Fuel System
    Stock flowmatched L67 injectors from ZZP
    Wbodystore High flow pump
    Fuel pump wire(haven't done this yet)
    ZZP highflow fuel filter
    Exhaust
    S&S coated headers
    2.5" mandrel bent downpipe
    2.5" mandrel bent catback
    Flowmaster 50 series Muffler. 1 inlet and dual outlet to 2 Fasttoys 3" dual rolled exhaust tips.
    Misc:
    Custom Air Intake
    Odyssey Lightweight battery
    Nitto 555 Drag Radials 245/50/16 with fuzion 225/60/16 rear tires. These are all currently on my stock 5 stars and this setup is just for the drag strip.
    FFP coilovers will be raised a few inches for the track
    For the track i'll do a bit of weight reduction. Remove the whole interior but the drivers seat.
    Oversized radiator 1 3/8" thick with DOHC drivers side radiator fan.
    Nitrous Kit #82021 wet kit
    Nitrous Maximizer kit(2 10lb bottles)
    2 bottle warmers
    2 remote bottle warmers
    dual purge kit
    dual stage nitrous kit
    2 nitrous exit pipes
    For the dual stage nitrous setup, i'm planning "so far" to have a 55hp shot for my stage 1 and a 100hp shot for a stage 2. But this is far down the road with lots of tuning.
    Car should be tuned and running at the latest of january 31. Earliest as 2 weeks from now.
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
    purrrrrrrrrdy i like the colour of the engine block. let me know how the gold race rockers work out for you, for some reason all mine wore on the same side.
    that thing should just scream! i want to see some vids at the track with the nitrous
    got zap-straps?
    89 Z24
    13.886 @ 96.16 mph
    street trim - slicks
      Defiantly.
      This engine should take the N/A 3400 record
        High compression, cam and headers. Gonna be a great street engine!
          Originally posted by blackbombshell95 View Post
          Defiantly.
          Cool! I should be a month or so behind Can't wait to see results.
          I like the rod and crank mods, and the very asthetically pleasing color
            blue reminds me of a Ford block... anyways, awsome complilation of parts, I hope you enjoy it... probably dont have to hope really... but um, what kind of HP and TRQ do you expect this thing to put down?
              Are you swapped to OBDII? How are you tuning it?
                yes, how are you tuning? very nice. very nice
                94 Grand Prix
                  Nice! Cant wait for this motor to be running!
                  3400/Getrag 284 5spd
                  350/NV3500 5spd
                  2014 Chevrolet Malibu LS
                    Same here
                    He is OBD2, and is going to have it tuned once its running. It has an MMS based tune to get it to the shop.
                      Same here
                      I have a BT racing obd 2 swap harness ready to plug and play. 98 monte carlo 3100 PCM
                      First thing once the car is running is to baby it over to the exhaust shop to get the downpipe/mandrel bent catback fabbed with my flowmaster 50 series mufflers and fasttoys tips.
                      The MMS PCM is to get it moving to the exhaust shop then to Bloods Enterprises for a dyno tune. I needed a pcm with tables for 33lb injectors plus the new gearing in the pcm so that It would be somewhat drivable.
                        250 whp n/a or bust(l67).
                        Easily over 300whp with nitrous. The flowmatched heads/ coated SI valves/ coated pistons should help with the nitrous.
                          i know im slow, but i havent heard of BT racing, they make obd 2 swap harness'?
                          94 Grand Prix
                            Brian Teel racing. The owner of motorswap.org
                            You send him the harness you want spliced together and he'll do it for $300 shipped back.
                            If you don't know what PCM to swap with he will know which is best.
                              Defiantly.
                              You've got some stiff competition, good luck!
