Well if you have nitrous and fuel nozzles installed in it then it will see gas vapors... And likely oil vapors just from normal use.
sigpicNew 2010 project (click image)
1994 3100 BERETTA. 200,000+ miles 16.0 1/4 mile when stock. Now ???
are you trying to call me a dunce? happy hollidays buddy....
El_Diablo:
ive seen using paper mache and epoxy or maybe even polyester to make a bulk of material that was used for a carb spacer
2012 Chevy Sonic Turbo 6spd
Just a little update. I worked on the spacers for a while Saturday until my buddy's porting tool took a shit. Hopefully tommorrow I'll go over to the shop and work on them some more. All that is left is to finish shaping the ports and trim off the excess material. Here's some pics as promised.
I just traced the gasket onto the material.
Using a hole saw, drill bit, and drill press I roughed out the ports and bolt holes.
A little port shaping with a porting tool (die-grinder) and a carbide bit.
After I shape ports to the correct size I will get some sand paper and smooth them out. That way they are nice and smooth and port matched to the gasket. I also plan on port matching the intakes.
