I purchased the crane gold rockers from another member on v6z24. i unexpectedly recieved some arp rocker studs, which to my assumption were the right ones for using them in a 3400. the issue i have is:
1. the studs i recieved also do not directly thread into the stock rocker holes, the studs have a larger size threaded head end. I did not see anywhere that the stock holes must be drilled and retapped for these, is that right?
2. bigger problem, when i slide the rocker over the top of the stud, the rocker body rests and rubs on the base of the stud...? not sure on this.
so...what is the difference between using the 8mm, and 10mm studs?
the ones i have look just like the ones i have, (besides actual diameter under assumption).
i have a 2003 3400.
do i need different studs, or is there supposed to be modification that i had not seen before?
thanks
cody
i have a 2003 3400.
thanks
cody
