I tore down my 3500 today and found a little problem..
Keep in mind, it ran perfect aside from smoking b/c of the valve seals. This is deffenetly a head scratcher. I was running Camaro 3.4 headgaskets which are around .020" thinner than the FWD ones. Exaust lift @ valve is .549 and 293 advertised duration, cam is 4 degrees advanced.
these marks are .034" deep, all 6 pistons have them. All from the exhaust valves. The valves are not bent and show no signs of anything, not even a clean spot.
I spun the engine during assembly and watched for any signs of piston to valve contact, saw nothing. Heard no weird noises on startup, no knocking or anything.. Hell, i might even have a datalog of the first start. Maybe the rods stretched a little too much on the many trips to 7000 RPM.
.jpg)
.jpg)
I had planned on upgrading the pistons, atleast now i know that i'll have to get valve reliefs cut in..
.jpg)
.jpg)
