Alright, first off do I even want variable assist? Is it nice to have or just sorta pointless?
I ask because the power steering pump I am using on my 3500 is going dead (original one from the 3100). The fluid is all nasty and it squeals like crazy, and the lines are covered in fluid. However the pump does not leak, leads me to believe that someone put additive in it at one point or something.
I really don't feel the need to replace the lines, just the pump.... lines look like a pain
I figure while I am at it, I could add variable assist. I don't think it came as an option in SE's, however if I look up GTP's their pumps have some with variable assist. I believe that I also have the wire for it, I have 1 unused 2 wire plug that was unused when I got the car. It is red and is on the fuel injector harness and would be perfect to reach to the power steering pump.
Is it as easy as just getting a pump for a GTP with the plug on it, and install it and plug it in? Could I get a pump out of any other car that would be stronger/better?
I assume the PCM would have to feed it data? My PCM is out of a 97 venture... so I guess I hope it could output that signal
