I just found out that the Chevy 400 large journal motor uses almost the same size main jounal, 2.649" compared to the 2.647" of the 60v6. Just figured I'd point it out for anyone that wanted to research it further. Maybe a .002" shim for the upper, or perhaps boring out the block side to 2.649" and using oversized 400 bearings. No idea if the bearing/journal widths are the same though.
1970-72 was 4 bolt main
1973-80 was 2 bolt main
I have seen splayed main caps to convert a 2 bolt main block to a 4 bolt cap, so there is a difference in the block.
