I have been comparing the Comp Cams 26915 to the 26918 springs. I see that the 26918 has a little larger O.D. at the bottom and is about 25 lbs. pounds heavier open and closed than the 26915. My cam is the 1161 grind from the 60*V6 store with 210/215 Dur. and 531/531 Lift. Which would be best and can I have your opinion as to why? Thanks.
Comp Cams valve spring question
