Hi all
I have had my cam ground,and Have some concerns of course..
I have a 95' grand prix with a 3100,3400 upper&lower intake and throttle body..
Here are the specs,this grind is from comp cams
Gross valve lift intake .427 exhaust .427
duration @ .050 intake 210 exhaust 210
Lobe lift intake .2850 exhaust .2850
Lobe separation 112.0
do these seem feasible for a OBD 1.5 computer? Will I defiantly need longer push rods,and do I need new valve springs?? The parts guy told me that the original springs would be ok,since the factory cam is so puny that,they really never got any wear..
I have a little concern that the thing isnt going to idle,although there is a adjustment screw for that if I am forced to use it.. Or is this grind going to be to big? If there is any more info I should have included let me know..
My transmission is also at the shop getting beefed up,Same guy rebuilt the one in my work van and got it shifting real nice and firm,and has found parts to make my 4t60e do the same,Cant wait to get it going,hopefully in a week and a half
One more thing,how does one determine preload on the lifters??
Thanks
Russ
Thanks
Russ
