I have a 75mm, but wondered about the 70mm TB mentioned earlier by Mars.
3500 plenum question
i was using a ported 4.3 tb and made up a custom adapter in my highschool machine shop class. as u can see theres a huge bottle neck on the 3500 plenum that i just never got around to doing before i sold it...only problem was u had to work out the linkage issues with it..i regret selling itLast edited by MidnightriderZ24; 11-07-2007, 12:18 AM.[SIGPIC]
12.268@117... 11's to come!
Yes, it's a bolt on deal. As I said earlier.
It's made by ford racing, and the nice thing about it is that it has a nice lip on the outside of it, so the charge pipe can be clamped on really really well with a 3" coupler.11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
see kinsler racing or electromotive for remote iac. i have the electromotive model on my fiero. a little squirely if u ever get a vacuum leak... over all it worked great.
i have a mustang tb as well, but never could get the tps to sit lower than 1.02v at idle withought notching the sensor mounting ears.the result was either correct idle or correct wot (PE mode) could never get both3500, 1280 cam and PR, ls6 valve springs, port and polished heads, ported lim, ported uim, 4.3 70mm tb, ported trueleo headers and y pipe ALL FOR SALE (minus the car)
2012 Chevy Sonic Turbo 6spd
