Thats a bit excessive on the personal stuff don't you think? Yes, he told us he doesn't learn unless he does it. He asked the same question a few times and ignored everyone. I don't care what he thinks of the motor so long as he posts pictures of what he did to it. Now we know what happens when you run without a MAF. This belongs in the wiki.
OMG My Engine is Toast
how the hell did the valve end up in the piston like that. the thing did a 180 and stuck itself in the piston.
lesson learned dont let other people work on your car especially with stuff concerning superchargers.
you did ignore multiple people telling you in multiple topics to run a maf or else you trash the motor.sigpic
99 Grand Am GT
1357 cam 227 233 .050 dur 515 515 lift 112 lsa
What part of mine blowing up without a MAF did you not get? I never like hearing of anyone blowing up but this was predicted months ago......good luck with the Yaris?
And if that valve is sticking into that piston.........someone staged it........ cause thats backward of a valve smashLast edited by zofo61; 11-02-2007, 09:15 AM.
Is the entire valve in that piston?!?
I can see no possible way for a valve to turn around and do that... unless somehow the valve got sucked in when the piston was down, somehow turned around then when the piston came back up it smashed through the piston.
But still... forged piston > valve. That valve should have twisted up, not gone through the damn thing.SpudFiles
Theopia
Enjoy life online.
I can't complain about my car.
must have 300+HP, and is pretty reliable. NEver had engine issues, it doesn't burn oil or anything.
I have a rather large intercoller, maybe that helps, and also tune with a 2 bar and OBD1.
Stock pistons, as well as other internals.11.92 @ 122 MPH 3400 91 Cavalier Z24 Intercooled S/C. -totalled-
Originally posted by kflo 93 gt View PostDude, you highlighted the goddamn problem in your own fucking post. How much more ignorance can you display? I'm done with you forever, keep away we don't need you clogging up the forums with dumb posts anymore. Good riddens to one more IGNORANT tool.
No that's not just you Ben, looks like somewhat of a lean burn issue wouldn't you say?
edit: I'm sorry to be a dick, but this guy is insulting every one of us here. He made 2 dozen posts asking about redundant shit, which he listened to none of - obvious by his piston choice... I can think of 1 company for sure that I bet got recommended that would've costed half as much that I'm sure he never looked at. Plus the entire MAF issue, how many threads and posts was that? Sorry, but I have no sympathy for ignorance, none at all.
Originally posted by SappySE107 View PostThats a bit excessive on the personal stuff don't you think? Yes, he told us he doesn't learn unless he does it. He asked the same question a few times and ignored everyone. I don't care what he thinks of the motor so long as he posts pictures of what he did to it. Now we know what happens when you run without a MAF. This belongs in the wiki.
Im guessing the timing chain skipped so bad it threw my valves st8 into my pistons.....My chain has like 1/2 inch of play in it, I could almost take it by hand
Originally posted by john_V63400 View Postthese engines suck, ive experimented, and Im never going with a 3400 to make a beast again.Originally posted by john_V63400I love the engine, wish this fatal flaw wouldnt of happened
Sorry this happened to you, but please stop saying that it was tuned properly. From what I can see, you are a 660/tuning newbie and you are fighting with people that have been doing this stuff for a very long time. Everyone on this site told you that you needed the MAF to get proper tuning, but you took it upon yourself to try to get it tuned without. Shame on whoever did the tuning to not have told you to come back when you put the MAF on. If I were you, I wouldn't go to them or your mechanic again.
even if it didnt blow up and you decided to continue to run without a maf you would have roasted the trans anyway from running without a maf.
unless rsm somehow magically found a way to make the trans run at normal pressure's with the maf unhooked.
i still fail to see how the valve got stuck in the piston like that especially a forged one.sigpic
99 Grand Am GT
READ CAREFULLY.. I had already had plans and in the process of adding a Ls1 MAF I did not ignore anyones advice, My engine was absalutely safe, my tuning and fuel ect. and I have dyno vid and sheets to prove it. Now my engine would of been better with the MAF..Yes, i know that, but it was running safely and with no problems other than the trans. unfortuneatley this happend, now I cant add it. But this did not happen due to no MAF.
On my other engines where I did not get a dyno tune, my engine internals looked terrinble, Excessive build up on the pistons, the engine just looke awful compared to this engine with the dyno time. And this engine had substantially more miles than my previous engines with no Dyno time. the difference was clear.
Originally posted by john_V63400 View Postits not a lean issue!!!!!!!!!!! how many times do I have to repeat myself, the tuning was proper.
and how many times do you have to be told.
...IT IS IMPOSSIBLE........DO YOU UNDERSTAND.............IMPOSSIBLE......
To PROPERLY TUNE WITHOUT A MAF AND ONLY USING A 1 BAR MAP With BOOST
PERIOD PERIOD PERIOD
