Help Installing throttle body 97 3100
  • Help Installing throttle body 97 3100
    I searched a couple of sites and cannot find a how-to on swapping throttle bodies. Will I need to remove the UIM? If so, will I need a New gasket?
    Originally posted by wozxx...{is 92 mph in a school zone illegal?}
    I was going relatively fast thru a school zone and was caught. However, I managed to zip into a neighborhood and evade the cop. Could I get additional tickets by trying to run?
    Do you just need to swap the TB or the TB plate? If its just the TB, Theres only 4 bolts... Two that hold it onto the UIM and two on top for the linkage bracket. Youll also need to take off the coolant lines that run to the TB.
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
      Both, but I read the instructions for how to take apart the linkage so I'm good with that...thanks for the response...I appreciate it
        Stock 97 3100? What size throttlebody?
          Swapping stock for RSM's version of 62mm.
            Wouldnt that cause a problem as the Tb opening is much bigger than the plenum opening?
            BTW since were on TB's, Ben do you need 3400 linkages? Ive got one at home that Im not using.
            350/NV3500 5spd
              You will need to port the manifold to 62mm as well. If its the stock 97, you have small port manifolds. Better off swapping to large port manifolds and porting that out to the larger diameter.
                Yes, I always need linkages with the TB plate screws.
                  Hmm maybe payday I'll buy on of yours....the Stage 1 3100 Lower Intake is already ported and costs a flat $200 before shipping right?
                    Ill send one out your way this week.
                    350/NV3500 5spd
                      Correct, 200 for a ported lower intake plus shipping to your door.
