Does anyone have good luck with these lower intake gaskets with boost? Im using an 01 3100 topend and the gaskets seem to be plastic... My car had really high idle after i boosted it hard one day, The gaskets look good but how would you tell if theyre bad? they look plastic.. no sealer at all? Should i reuse the bolts for the 3rd time? I think theres a ton of washers on the bolts too... i dont know if that would affect the torque spec. Any help is appreciated , this is the last time im taking my motor out so that goes for the intake gasket as well.
Need tips on LIM gasket, boost-proof.
what do you mean by bigger UIM gaskets? Ive got that gasket set here ( although im just waiting for parts to come back ) and those gaskets are deff for the large port.sigpic
3400/Getrag 284 5spd
350/NV3500 5spd
2014 Chevrolet Malibu LS
Originally posted by 19Cutlass94 View Postwhat do you mean by bigger UIM gaskets? Ive got that gasket set here ( although im just waiting for parts to come back ) and those gaskets are deff for the large port..
http://s158.photobucket.com/albums/t...t=100_3214.jpg
I got the 3400 gaskets to work on some 3400 heads I got. Just need to find a cheap big port 3400 IM set.
Originally posted by 19Cutlass94 View Postwow thats strange you got metal UIM and I got the paper UIM. I think ive been screwed!
Originally posted by El_Diablo View Postthe 3500 top end set also uses a metal LIM gasket if memory serves me correctly...
Originally posted by 3XTurboAgain View Postso MS 98003 T is LIM gaskets i need? I plan on getting the UIM spacer anyway. All i need to know because im pretty sure thse plastic ones are crap. Thanks
Originally posted by El_Diablo View Postthe 3500 top end set also uses a metal LIM gasket if memory serves me correctly...1994 Chevy Corsica. Parted out. Just a rotting shell now
Best 1/4mile ET - 12.9
Best 1/4mile MPH - 111
1997 Ford Ranger Splash
Daily Driver
Originally posted by loner666 View Postreally? damnit..i wish i knew that before..the gasket Ben sent me for my 3500 top swap had plastic lower intake gaskets
Here's a pic of a 3500 gasket set, I got the same one from GM...
