I've been thinking about building a 3900 for my Fiero. I've heard that a 3500 uim will swap onto a 3900 lim, if this is true, which is better? I would also like to run a turbo in it, still have to done more research. Also any ideas on cam profiles,turbos ,compression ratios, and TBs.
Best UIM for a 3900
If you can't control the 3900 variable intake properly, then the 3500 intake is probably the best bet.
Did you see Joseph's turbo 3900 Fiero?sigpicNew 2010 project (click image)
Yeah I don't know if it's PWM. If not a RPM switch would be the way to go defiantly.sigpicNew 2010 project (click image)
