rattle and roll
  • rattle and roll
    Yeah I was driving and hit 5600 RPMs and the engine shut off
    It was a rattling ticking noise, the engine imediately shut off
    I pulled over checked oil, water, gas, checked for cracks in the block or any noticeable damage. Nothing
    It cranks, and starts for a moment while making a rattling vibration noise
    I can definitely feel it and hear it.
    I cant believe this is happening I had my car tuned and everything.
    Ive been taking it easy on it.
    Uhhmmmm...Any sugestions
    I know its not a blown piston cause it sounds way different.
    Oh and it smell like gas terribly when I try and start it.
    Yes two suggestion, get it looked at by a professional and don't drive the car until the source of the noise is diagnose. If you’ve spun a bearing you’re only going to do more damage to the crank, block or cam depending what bearing(s) spun.
    2006 G6 GTP MT6
    Vector Motorsports ECU
    Classic Performance 2.5 Inch Exhaust
    v6h.o. Downpipe
    Custom Intake
      yeah it wont run long enough to drive it anyways.
      I was thinking I spun a bearing.
      Any other sugestions
        hard to say, its possible you broke a timing chain or did actualy break a rod. id start with a compression test.
          I would turn it over by hand first with the plugs out and belts off.
            What Rod, not the conecting rod....
            what would compression test do
              yea turn it over by hand, if it doesnt turn smoothly you have mechanical damage. a compression test will tell you what cylender the problem may be with.
                When your turning the engine by hand with the plugs out... if you can take off the front valve cover... if everything turns like its suppose to, the timing chain isnt broken... but that doesnt rule out that it jumped a tooth..
                3400/Getrag 284 5spd
                350/NV3500 5spd
                2014 Chevrolet Malibu LS
                  I had my torque set at max 260 for a 2 to 3 shift via HP Tuners
                  Then I set it at 360, durring my test run was when this happened.
                  Could that of caused it....too much torque
                    Yeah Im almost positive its my timing chain, the last couple of days my car has been running rough and it has even back fired a couple times, and Ive been hearing a rattling noise from my engine while driving, I just dismissed the noise cause it was intermitin.
                    I didnt know those were signs of a timing chain failure, or a skipped tooth.
                    Specially the rattling noise, prolly the noise from the hain cause it was loose.
                    Any Thaughts
                      get that MAF in yet?
                        I ordered my LS1 a MAF and pigtail so not yet
                          Any Thaughts
                          What have you done to diagnose this?
                          2006 G6 GTP MT6
                          v6h.o. Downpipe
                          Custom Intake
