Originally posted by Monzsta
View Post
3500 crank
I just want to clear on thing up, the forged crank is the better of the 2 cranks? and to inspect if you have the right crank with out dropping the oil pan, you remove the ballancer bolt, and you will see the number 7484, or do you have to remove the ballancer? i'm Just curious, a complete motor popped up for $300 with 70xxx km. a picture showing where the number is would be sweet. thanks.
Originally posted by bob442 View PostI just want to clear on thing up, the forged crank is the better of the 2 cranks? and to inspect if you have the right crank with out dropping the oil pan, you remove the ballancer bolt, and you will see the number 7484, or do you have to remove the ballancer? i'm Just curious, a complete motor popped up for $300 with 70xxx km. a picture showing where the number is would be sweet. thanks.
it was from a 05 malibu, # read on crank 4122111, # on timing chain cover 12593231 2374 ROUSH, and block was 3074. I would *like* to get the forged crank as i am an abusive driver, need i say more?
i got the crank number from here (its blurry as hell so i wrote it down)
Roush?
damn, so 2 1/2 years after i started this thread.......i get my stroker rotating assembly from the shop in Colorado, and then it is back to SD where I need to find a new machine shop to finalize things up for me...
pictures and details will be posted when i get the stuff but basically
JE stock compress pistons, manley rods, 3.7 displacement with a 10mm stroke
Got it yesterday!!! Got home late last night, about 1400miles round trip between the two machine shops and home...
The corolla with two blocks, a set of heads, and other various items in the trunk......lol.....
about half of it on the garage floor
Comparison of the two cranks, bottom (closest to camera) is forged stroker crank, top is stock 3400 cast crank...
Forged crank
rods compariston, far left is stock 3400 rods, middle is narrowed Scat SBC rods, Right is Manley narrowed SBC rods..
Manley rods seem pretty light! off hand anybody know the big and little end weights of stock rods?
Piston/ Rod combo, pistons are custom JE pistons with a 3.635 bore
deep dish baby!!
Originally posted by Joseph Upson View PostDo you know whether or not heavy metal will be needed to balance the assembly? The reluctor ring mounting circle has an assymetric area that would affect balance if removed such as in your case in addition to the parts changes.Last edited by kwhauck; 03-07-2010, 08:12 PM.
