If it has the wide seem line it's steel even if you can't find the last 4 digits of the steel crank part number on the crank snout. I don't remember what they are but they're posted. More importantly they probably only used the cast iron crank in the early engines as I have only seen one in a picture on this forum side by side with the steel version and it had the characteristic thin seam line on the front throw.
I recall the debate I had some time ago here after noting that my crank looked funny compared to what I was used to a cast crank looking like. I called GM parts direct and was given two part numbers for the 3500 crank the difference being the cost and the shipping weight of the crank, my numbers matched the heavier more expensive crank and along with the pictures confirmed it was the steel version. It proved that just because GM didn't say it, it doesn't mean it isn't so.
Forged or not, it should be considerably stronger than the iron crank and lets not forget the benefit of the larger diameter throws for increased bearing load distribution and further stiffening of the crank to make high rpm safer. The fuel cutoff at least for the 3900 was bumped up to about 6400 rpm and thats with a heavier reciprocating mass. I don't see any cause for concern with the crank.
