What was the operating temperature of the motor with these numbers? You need to get that thing to 200*F MINIMUM. Don't try and dyno it at 160~180 thats way too low. An engine will make more power the hotter it gets up to about 220* But running at 220* leaves too little of a safety margin so always keep it between 200* and 210* Get rid of the 160* stat and run a 195*. The V springs you chose are a little stiff for the application but still acceptable and wont bother the power output. The other thing I would change is the intake top. It is easy do do an worth a look. If you want swap the heads around and see what happens. You should be able to get over 200HP. Guys with 3.4L's and TBI induction are getting 180 at the wheels of an S-10.
Did the operator bother to get the engine up to full temp? Richening the mixture and adding timing is not the way to add power all the time. Did he try and lean it out and take some timing out?
My other curiosity is how you could have killed 3 motors in 1 year?
