Hi, I'm a engine builder with 30 yrs experience but I can't quite put
my finger on this. A dealership down the street has a 1996 Grand am
3.1 with a rod knock. Engine was quiet except the rod would sound-off
if you reved it. Their mechanic (Joe) pulled the engine, put in a reground
crank and new rod and main bearings and 1 reconditioned rod. He only
had 1 head off the engine. Following this, the lifters are noisy and they have never quieted down.
They put in new lifters, no change. (would have been my guess)
The gage on the dash shows 60 psi and varies with rpms so we are
"assuming" the oil pressure is good. I told them to do a live test which they
will do... but for now I'm just passing on what info I know. I was there when
he had the dist drive out and spun the drive shaft and oil was pouring
out of the hole in the block indicating the pump is for sure working.
My question is, if he installed the earlier main bearings, would it block oil to the
top of the engine ? He never had the cam out. There is zero oil flowing out
of the push rods. I tried finding a oil circuit diagram for the engine but
am unsucessful.
I know Joe did NOT mic the crank
so he could have a undersize crank (happened to me once), and there
are a number of other possibilities... but I am wondering about these main
bearings.
Clevite shows a main bearing change starting in 1990 they went to MS-1897 P, before that it was MS-1631 P and I remember something about the holes being different... just a hunch if he had the wrong mains in the engine could that block oil flow .
Thanks in advance for any help, you can also contact me at gearhead4you@yahoo.com Mark
am unsucessful.
bearings.
