the Lingenfelter TPI had equal length runners to start with. you can't do that with his intake.
building an intake manifold, input needed
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
i wont be needing any of those flanges, the point of building the middle intake is to get away from those small openings in the top flange. i will be making custom flanges for between the middle and upper intake.
im planning to use round tubing. when you look at a sheet metal intake for a v8, typicaly the runners are 2x3" and have rounded corners. with my intake, it would be around 1 1/2 square tubing, and it has sharp corners. coupled with the fact that the round tubing of the same size hasa larger area, this is why im going with round tubing. it will however be flattened a bit, making it more like oval tubing.
building a tpi style intake wouldnt be that plausible for me. the runners would have to have a fairly sharp bend in them to clear the hood of my car, and getting 1 1/2" aluminum u-bends is impossible.
im still unsure what im going to do for a plenum. i know it wont be round, thats for sure. im planning on having the runners come straight out and they will be cut off at an angle and have flanges for the plenum (mabey). the problem with that is the runners for each bank will be about 18" apart, meaning a plenum would end up well over 200 cubic inches, wich is way to large. im tossed up over doing 2 seperate plenums with dual throttle bodies (dodge intrepid setup) or building something like a 3.4l camaro setup were the 2 plenums are fed by a large singe throttle body.
the lower intake realy isnt that bad, the ports have been opened up to match the gaskets and heads, and the heads have had extensive work done. i realy dont think the middle intake is that bad either, except for the sharp curve. i had thought about cutting the flanges off and starting from there, but by the time i do that i may aswell build 6 new runners. besides, id still be dealing with some 6" runners and some 10" runners. my runners are going to be 8-10" long, totaling around 17" from the valve. still a little shorter than optimal, however its not practical to make them longer and still have a hood.
Originally posted by sharkey View Posthis plenum would be way to large for an n/a motor, however boosted im sure it would have worked very well.
and you WILL post pix!!!! Franz attempted his own using the existing lower. pretty cool how it ended up, but he lost most of his lowend and the powerband bacame peaky.Andy
now why would i poist pics??? i think id rather come up with this idea, do it, get everyone all excited, then leave you all in suspence lol.
i am willing to lose a bit of low end power to gain more up top. my headers are better off for higher rpm, and the motor is built to take 7k.
lol.....yeah you don't spend much time in the low rpm area in the 1/4! specially the 2.8.Andy
ok i wont have any pics up this weekend as ill have nothing much done. i havent got my flange back and the tubing i picked up for the runners is just going to be too large. being a long weekend none of the metal shops are open today, so im screwed untill tuesday
well, bringing this back up from the dead, ive got some stuff done, not a lot. my guy dropped the ball on the flange, i dont think he knew what he was getting into when he said he would do it. its rough cut, but now i gotta finnish it with a hack saw and file. the upside is i have all the runners cut out and ready to be welded to the flange.
i still gotta design the plenum and flanges for it. im running out of time, the last street legal drags in october 5th, i want this on and tuned before then.
Heh, I hack sawed out an adapter from 1" thick aluminum. That was fun!!! But it can be done!Looking forward to progress pics.
sigpicNew 2010 project (click image)
