are you using the Bosch or the Honda style NTK sensor with the Tech Edge?
Fired my engine on the PRO firmware today.
Originally posted by v6h.o.are you using the Bosch or the Honda style NTK sensor with the Tech Edge?
Originally posted by v6h.o.thanks for the advice. i'll look into the Tech Edge a bit more. i think i remember seeing an Ad or even a write up on it in one of my australia car mags i brought home.. have too dig through them.
been looking at the Holley unit. (its dead at work right now)
seems pretty cool and simple to use.
doesnt actually say it but it sounds like it should work for DIS Ignition systems:
Originally posted by HOLLEYTiming control function can be achieved through the use of:
..........- Small cap computer controlled GM HEI (stock GM or Holley PN 890-160).
..........- Large cap computer controlled GM HEI.
..........- Ford TFI distributor.
..........- Magnetic crank trigger.
..........- Hall effect crank trigger.
Looks promising. im looking for something around the 800-1000 range as i just know nothing of tuning with GM code to tune my own chips.
Yeah I actually bought my two commanders off ebay one for 265 had the seller close early the other for $367 I got the full 670 cfm commander tbi kit retails for $1299 from jegs. Then they upgraded me to the PRO for free! Only cause Im special.Basically by being smart I saved over one thousand dollors just on that.
Originally posted by bszopihttp://www.widebandcommander.com/
Here is one of the ones I just recently have and am very intersted in...1992 Chevrolet S10
2.8 v6 tbi 5 speed
Originally posted by 614streetsOriginally posted by v6h.o.are you using the Bosch or the Honda style NTK sensor with the Tech Edge?
Yeah you can plug it right into your exsisting harness and do a repin. It'll do the DIS Setup.even better. just repin the connector and go!
Colin
Tried posting this like 4 times last night, but the firewall at work was acting wierd. I could post in other sections, but I couldn't post in this one. Anyway...
Since you don't like the analog Dynojet WB (although the datalogging would be nice), try this one on for size...
And, for those that already have an Autometer AF gauge, you can continue to use it for a WB display using this adapter:
And its a pretty reasonable price as well...-Brad-
brad dont know if youve ever seen them before but honestly one of the best wideband controlers out there on the market is the FJO unit.
i wish i had the $$ to spend on a brand new setup like this.
very good product. and locally based (winnipeg)
they used to do military products (possibly still do?) and branched off into the automotive engine managment and fuel air control areas. very good products. have never heard anything bad.Colin
I've seen the FJO ones before, but again... $$$.-Brad-
Originally posted by bszopiTried posting this like 4 times last night, but the firewall at work was acting wierd. I could post in other sections, but I couldn't post in this one. Anyway...
The FJO is good. $$$
The PLX is good looking, but the Tech edge display walks away from that display hands down , but the PLX price is good.1992 Chevrolet S10
2.8 v6 tbi 5 speed
