Took a delay and time to correct a problem that arose but I finished converting the engine from narrowband commander 950 control to full closed loop "PRO" Wideband run in series with my tech edge v 2.0.
I was given the new Pro software upgrade from Holley before it was released to the public(still not available).
Ive set it up for now to run 12 a/f ratio under boost , full closed loop.
Without a cog belt the best it can muster is eight lbs five of which can be seen on the gauge off idle in nuetral.
