Hey guys, I've just rebuilt the 3.1L engine in my 92 Lumina. I fired it up and let the engine idle for a bit and could hear some chattering. There was also a ticking sound at first, but I believe that was coming from the transmission since I did some work to it, and when I put more tranny fluid in the ticking went away. Could have also been a loose nut, but that's not my problem.
Anyway, after letting it idle the chattering continued. After a while, the engine just died like it either ran out fuel or air. I tried turning it over, but it would only fire a couple of times and die, like it was choking itself.
The rebuild was stock except I put in an aftermarket cam, swapped the rocker arm studs for adjustable ones, and put in Comp Cams 1.6 roller tip rocker arms.
This is my first engine rebuild, and I tried to follow everything by a Haynes manual as well as the instructions from Com Cams. However, when I took off the valve covers I found that 3 of the rocker arms had worn the nut looser than I had it. So I assume the engine was not firing because the 3 valves weren't opening. There may also have been other ones loose, but 3 of them were definitely in a position where the pushrod would not lift the rocker arm enough to open the valve.
My big question is this: Have any of you had any problems like this with adjustable rocker arm studs? Here is my experience with installing these studs and rocker arms:
I zero lashed them and added a half turn about 3 times because I was paranoid, and I also had some other people check over them for me except for the final time. A weird issue I noticed was a few of the nuts didn't go on the stud as tight as they did the first time I used them, while the other nuts did seem to lock down fine.
Is it not a good idea to tighten and then back off the nuts more than 2-3 times? All of the nuts were tightened and backed off at least 2 times, but some might have been done 4 times. Have any of you had trouble like this with adjustable rocker arm studs and nuts?
What's a good solution for this problem? Should I get new nuts? My dad suggested thread locker might work. That would certainly be the cheaper route.
Oh and my last question for those of you who have done the rocker arm swap: When you zero-lash and add a half turn, should you be able to wiggle the rocker arm a little from side to side? I noticed on 1/3rd to 1/2 half of my rocker arms would wiggle a bit from side to side while others would be tight (yes I did turn the engine over when I checked them.) Also is the zero lash procedure going to be the same since I got a different cam? Here are the specs:
A.R.I Pro-builder Phase 2
Duration @ .050"
Intake: 204 | Exhaust: 214
Adv. Duration
Intake: 270 | Exhaust: 280
Lift
Intake: .420 | Exhaust: .443
Lobe Center
Intake: 107 | Exhaust: 117
Thanks guys.
Duration @ .050"
Adv. Duration
Lift
Lobe Center
Thanks guys.
