I've had a few emails to Delta Cams about regrinding my flat tappet cam. 94 Z24 3.1MPFI VinT. They are telling me that that cam has pressed on lobes. thought only the newer roller cams had those. isn't it a bad idea to have pressed lobes on a flat tappet cam? looking for verification.
Pressed on lobes?
Pressed on lobes?
Andy
fastest 1/8: 10.19@ 67.17
fastest 1/4: 16.16@ 82.70
62mm TB, 1.6 roller tip rockers, Ostrich 2.0, UD pulley, TB heater bypass, K&N, 180* stat, No cat, 99Grand AM dual cooling fans. 4T65E swap FDR 3.69, EP LSD, F.A.S.T. transmission controller, TransGo shift kit.Tags: None
Wouldn't a cam from another 60* work? MPFI doesn't have a timing lobe to worry about like the SFI's. This way, you can just order a cam made for a different year/model I'm getting ready to call them again for the cam in my new motor...
Also, I think they only charge like $30 more for a new grind.
no it can't.
i'd figure a shop that deals with cams with all the info they need should know if that cam has pressed lobes or not. the only thing i can think of is that they are thinking i have the 3100--even though i told them i had the flat tappet 3.1 vin T.Andy
Originally posted by torq455 View Postno it can't.-Brad-
either i was misinformed by Delta Cams or they just don't touch pressed lobed cams.Andy
Originally posted by torq455 View Posteither i was misinformed by Delta Cams or they just don't touch pressed lobed cams.
Thats not that great of a deal. You can buy a new cam and lifter kit from GM for $116 and thats Canadian dollars. The grind is the same as a Crane 260 cam. I though Delta cams was really cheep.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
Originally posted by betterthanyou View PostThats not that great of a deal. You can buy a new cam and lifter kit from GM for $116 and thats Canadian dollars. The grind is the same as a Crane 260 cam. I though Delta cams was really cheep.
Dealership man. GM Performance Parts sells in a competitive market so everything is priced accordingly. If you are buying OEM parts then your going to pay a premium unless you know someone.1993 EXT. CAB, 3.4L V6 TBI, 5spd manual. Sonoma
not big enough!!Andy
